switchmaster 400 replace with horstmann c27
View the thread, titled "switchmaster 400 replace with horstmann c27" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
johnnyphatboy
Hi Everyone
my switchmater 400 dial stopped working so i went on line for a compatible programmer. I found that a horstman c27 would work fine. the switchmaster controlled heating on, hot water on, or both, on a 3 port mid way valve, temperature controlled by roomstat and cylinderstat. when i took the switchmaster of it had, 2 wires to neutral, 1 wire to live, 1 wire to pin 1, and 1 wire to pin 3, ie only 2 control wires. can anyone advise on which pins i should connect 2 wires for full independant control of heating and hot water through the C27 programmer.
thanks
Hope this can help you out 🙂[DLMURL="http://www.thermsaver.co.uk/heating-controls/programmer-replacement.html"]
http://www.thermsaver.co.uk/heating...free-instruction-manuals.com/pdf/p3133382.pdf
[/URL][/DLMURL]
Reply to the thread, titled "switchmaster 400 replace with horstmann c27" which is posted in UK Plumbers Forums on Plumbers Forums.
johnnyphatboy,
Steve @ TheHeatingHub,
