Guest viewing limit reached
System boiler motorised valve fault
View the thread, titled "System boiler motorised valve fault" which is posted in Boiler Advice Forum on UK Plumbers Forums.
G
gregg1908
I recently changed a synchro motor on a system boiler motorised valve to cure a lack of heating.
All was well for a few months now when the customer calls for hot water it let's bye into the rads,am I correct to presume the motorised valve needs replacing since it has a new synchro.
sounds like time for the new valve, or possibly some thing stuck inside, sluged up
are you sure it is passing rather than a pipe work issue causing reverse circulation
some motors are more powerful 6 watts as opposed to 5 watt, could be a factor
Pipe work is fine it's always worked ok you may be correct the valve or sludge I will investigate further
Probably valve letting by. Even Honeywells, as good as they are, succumb eventually.
Reply to the thread, titled "System boiler motorised valve fault" which is posted in Boiler Advice Forum on Plumbers Forums.
gregg1908,
mountainman,
