s3dbw
OK folks,
I am really struggling with this one and it would seem my plumber is as well, so here goes the catalogue of events to date:
1. Back in the summer I upgraded my ancient boiler to a modern worcester greenstar, no obvious problems at the time as I was only running the hot water. At that time the system was power flushed and after 20 years there was a lot of sludge removed.
2. Fast forward to Winter when I start to use the heating I notice that at best the radiators are only warm even after all the usual bleeding etc
3. Plumber notices that the "on" light for the burner is no on as often as it should and reckons there might be a circulation problem, ie the hot water is not getting away from the boiler and the stat in the boiler is causing it to shut off, so the as the circulating pump is also ancient we replace that.
4. Still no significant improvement and I notice that the hot water isn't really as hot as it should be either, so the system is powerflushed again, more sludge removed, though obviously not as much as first time.
5. I fit a magnaclean to the system to keep taking out any residual sludge
6. Still not getting the temps, so plumber converts the system from an open (header tank) to a closed pressurised system.
7. Now with the new boiler, new pump, 2 X Powerflushed system and closed system, the radiators should be able to get so hot that you cant touch them, but even with the boiler stat turned up full they are best only warm and hot water could be hotter.
Suffice to say, I am starting to despair, so any thoughts would be appreciated
regards
regards
