Dante
A 2 floor (loft converted into a room) flat I let in a period stone walled/high ceilinged building has a heating system installed in the 80's. The boiler is a Thorn wall mounted system boiler which, IMO as the landlord, is reliable and cheap to maintain when necessary.
2 problems identified by tenants and observed by myself:
- pilot light randomly goes out in windy weather
- The loft room radiator doesn't get very hot
- The boiler could be relatively inefficient and therefore put tenants off
The gas engineer that I call to maintain the system flushed the top radiator and its still not getting very warm. In his opinion the system is a one pipe system that should ideally be upgraded to a two pipe system with a combi boiler and TRV's as well as a room thermostat. I went for a second opinion and the engineer says it doesn't matter about the system, just cleanse the system, upgrade the boiler and install TRV's and a room thermostat.
My questions:
Other than looking under floorboards etc. is there a way to tell if its a one or two pipe system?
Would a better exterior flue solve the pilot light problem?
Do I really need TRV's on existing single panel radiators as well as a wall thermostat?
Could I not just install new double panel radiators and turn the pump up?
Are the engineers talking sense?
My questions:
