Tap connectors any recommendations??
View the thread, titled "Tap connectors any recommendations??" which is posted in UK Plumbers Forums on UK Plumbers Forums.
macka09
Hi folks
Really daft question here but what tap connectors are you all using?
I’ve picked up a couple of end feed with fibre washers today and the washers didn’t fit. Just would not fit over the little spigot that sits just inside the tap.
I ended up using different washers which were baggy and not sealing to good.
These were 3/4” for bath taps. Flexis were out of the question as that was what had blown.
Cheers
I use polypipe tap connectors as its a million times easier to use them in tight positions and don't need as much torque, done the same for tank connectors (although fitting these are few and far between nowadays!)
If its a pedastal basin with twin taps and I can't use flexis I'll use soldered with fibre washers
Can the washers be bought on there own?
Reply to the thread, titled "Tap connectors any recommendations??" which is posted in UK Plumbers Forums on Plumbers Forums.
macka09,
Matt0029,
