Tap head fallen off HELP!
View the thread, titled "Tap head fallen off HELP!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
Garyn666
As you can tell I am definately not a plmber! just a normal guy in need of some help.
The head of my hot tap on my bath ( two taps mixer) has fallen off. I cant get it to fix back firmly enough to turn the water on and off properly. The spindal attached to the base of the unit still looks as if its ridges are ok but the tap head will not fix firmly to it.
I am now in a position where I am struggling to turn it off. HELP!!
Is there a quick fix until I can get the taps replaced?
pliers will turn the tap off
how did it fall off?
basically there is a spline on the valve which has the ridges and the handle fits over this and is secured by a screw
if the spline has now worn then you can try the manufacturer for a new valve and/or handle
If you dont know the manufacturer then im afraid new tap
You can get universal replacement tap heads, although as Tom says its probably better to get new taps
Thanks for info, but is there anything I can do for the next couple of days until I can get to a supplier for a new tap?
well you could super glue it on if you really wanted as you dont need to take the tap heads off to replace the complete tap
or does as my friend was doing for the best part of a year and have a pair of pliers next to the tap
Reply to the thread, titled "Tap head fallen off HELP!" which is posted in UK Plumbers Forums on Plumbers Forums.
Garyn666,
Garryaca@yahoo.,
