Tap still dripping after valves have been replaced?
View the thread, titled "Tap still dripping after valves have been replaced?" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi I have a dual lever bath tap / shower mixer and have replaced both ceramic type valves on each tap. Since then the tap continues to drip and was hoping to get some advice, thanks I’m advance
It's probably a seating problem. The machined surface of the tap casting underneath the cartridge must be in very good condition so that the silicone gasket at the bottom of the cartridge forms a water tight seal. Inspect and clean / polish / descale / regrind / replace tap body (depending on severity of problem).
Thanks I’ll try this, wasn’t sure whether the seating could be a problem with it being the quater turn ceramic cartrdige (rather than the valves with a tap washer) thanks again
Tap reseating tool. Also when installing cartridges it's good practice to leave the tap open when you first turn the water back on. Allows any debris to flow through rather than potentially damaging the ceramic discs.
Reply to the thread, titled "Tap still dripping after valves have been replaced?" which is posted in Bathroom Advice on Plumbers Forums.
Jk6969,
Gazza91,
