View the thread, titled "Thanks!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumrob
20 replies after my initial plea for help and I have a functioning system.
I shoved a hose into the top inlet feed from the top up tank and flushed what ever it was through the system. Several refills later and I have a working system. Pumps are a bit noisy but I hope that they will settle down. Many thanks to you all.🙂
give it a day or 2 and them bleed you rads (switched off) to get rid off the last bits of air
nice one.
Thanks for the thanks🙂, but I can't help noting that you started four topics, including this one, all on the same subject. It might have been better if you had put everything into just one topic.😉
You are right about the multi threads. Sorry about that. Guess I was getting a bit uptight about the problem and under pressure from m'lady to get it ****ing sorted. Covered my bases a bit. Job done and lessons learned.
Reply to the thread, titled "Thanks!" which is posted in UK Plumbers Forums on Plumbers Forums.
