L
lexicon101
Morning hope your all well.
So , I was at a flat that I am doing the whole kiboodle on last eve, and basically the architects of the owner, had got the cupboard dimensions wrong for the only viable place to fit the combi boiler & put a flue out from, only by 120mm lol..
Anyway I have been left with about 260mm maybe 280mm at a push , and have been looking at both the Glow worm flexicom and the intergras compact 24, both have suitable output for hot water and heating, as it is is five rads in total, nothing major size wise either in terms of rads , biggest room requiring something around 3kw when calculating !
So that said, I have installed neither of these, but as you look at the cupboard where the boiler needs to go , the flue would need to go out immediately to its left horizontally , both of these units from info that the respective sites have on them , do horizontal flueing yes??, but I am wondering as I cannot see clearance dimension on the intergras site, if there is anything I need to be aware of, need to do some recommendations sharpish, and have not had this issue before, the architect mentioned electric combi, but having read the fuel cost to run, especially in a cold scottish winter I think this would be prohibitive currently, and want to really use gas as a result .
So any info would be really appreciated
oh cupboard I have is 280 to door front when closed and about 600 wide, and plenty on height, It is the flueing I am concerned about mainly, and of course depth ..
cheers
L
cheers
L
