View the thread, titled "Thermal storage unit" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Connor Williams
Hello, I was called out to a job involving a DPS thermal storage cylinder.
The hot water from the taps is lukewarm even though the water in the cylinder is very hot.
The pump seems to be working okay so I have concluded the fault must be with the thermostatic mixing valve on the cold mains, the valve is leaking slightly anyway so I intend to renew it.
Is there anything else I should consider?
Many thanks for any help.
All the best,
Connor
Reply to the thread, titled "Thermal storage unit" which is posted in UK Plumbers Forums on Plumbers Forums.
