dgrs
Dear All,
We have a flat that has electric only. When we renovated it, we took out the unvented cylinder and installed a thermal store which also 'powers' a wet central heating system. The plumber who installed it had never worked with a thermal store and was convinced it wasn't going to work. It does work well but I fear it's been installed incorrectly so working very inefficiently.
My recollection is that our store (from newark copper cylinders) has one coil inside for DHW. There is then simply a flow and return for the central heating which draws water directly out of the store i.e. not how the DHW is heated. The plumbers installed the pump on the return side so, when the central heating is on, the water is 'pulled' through the system. I've no problem with this.
However, two things bother. 1. They installed an expansion vessel, but if the above is correct it's not a sealed system is it? If it's drawing hot water directly out of the store this water is replaced by the inbuilt header tank and is therefore an open circuit. 2. Because the hot water is taken directly out of the store for the central heating, the flow pipe (which is not lagged at all) is essentially heated up all the time whether the central heating is on or not. This is so noticeable that a couple of the radiators actually get warm even if the heating is not required whatsoever.
The outcome is I think I have a system which is hopelessly inefficient. What do people think the best way forward is? I'm thinking I need a way of separating the central heating pipework from the store itself so think maybe a motorised valve is appropriate and then heavily insulate the pipework up to that valve. If I'm right and it's not a sealed system, then the expansion tank is totally unnecessary.
Thanks for any thoughts you might have,
Dave
Dave
