Guest viewing is limited
Thermosat
View the thread, titled "Thermosat" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi people
Need some advice currently have a salus rt310i thermosat installed and it's a nightmare the WiFi connection drops out so heating doesn't come on
I wanted to ask can I install a traditional dial thermosat will this be difficult to do. I have attached I'm images of my boiler and current thermosat location.
It would be easier as Shaun says to fit a different branded wireless, and Salus are garbage. If the wiring isn’t there in that junction box for a dial stat, then you’d need to run 3 core wiring from where the Salus receiver is to where you would want the new dial thermostat.
Thanks for the reply. I'm sure the wiring is there as this is a new boiler and the old boiler had the traditional dial thermostat.
Below is a pic of where the Salus thermostat is. The wires for the old dial one are still there?
Reply to the thread, titled "Thermosat" which is posted in DIY Plumbing Advice on Plumbers Forums.
Indi_s,
ShaunCorbs,
