thermostat
View the thread, titled "thermostat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
It is a glow worm 38cxi combi, But my current thermostat has only got two wires 1 and 3 but the new one has got aspace for 3.
you want 3 and 2.
3 is common (live call from boiler)
2 is switched live to tell boiler to come on
1 is off not used.
double check the instructions but thats it if i remember.
it is also low voltage.
This is what my old one looks like. I have attached 2 photos if that helps.
The tx7501 is spdt which means that it allows powering off as well as powering on. Most applications require a call for heat and therefore the advice given above is correct - leave terminal 1 unused.
If you only have two wires then it doesn't really matter except to purists.
Reply to the thread, titled "thermostat" which is posted in UK Plumbers Forums on Plumbers Forums.
jasonjkd,
Deleted member 2053,
