Thermostatic Mixer Shower from Woodburner Fed Cylinder
View the thread, titled "Thermostatic Mixer Shower from Woodburner Fed Cylinder" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
WHPES
The situation is thus: Customer has changed LPG boiler to a woodburner. Fancy shower set-up in bathroom.
Woodburner is obviously not set to heat the cylinder no higher than 65 degrees. Shower pump and mixer not designed to take water higher than 65 degrees. I need some device to mix the hot water with cold prior to going into the pump but most mixing valves are only rated up to 85 degrees and the cylinder could potentially get hotter.
One idea I have is to use one of those solar mixing valves which work up to 100 degrees. Can anyone recommend one or have any better ideas? I'm sure I'm not the first person to encounter this and I am also sure there must be things on the market to do what I want.
Hi. You have got a problem. Coupled with the possibility of a fault over time with a complex to solution. Why not a standard mixer/blending valve and a cylinder stat wired to a audio alarm of some kind, set to work at 80c. After all it was the householder that choose the change. When you drop from Range Rover to Land Rover you find differences and have to live with them. Good Luck
Just been onto Reliance Water Controls and the nice lady there sorted me out. Apparently it's a common thing asked for these days and they recommend a Solar Tempering Valve for this situation. These work up to 99 degrees and reduce down to 65 degrees which is exactly what i need. They do work fine in the supply to a shower pump provided the supply is not restricted.
You need to be careful to get the right one as there's a number of different versions and some don't work under suction (i.e. if connected before a pump). The only downside is the price (at about £80), however the customer has plenty of dosh. They have developed them for the solar market and the eco friendly types with the fancy bathrooms, and she said they sell quite a lot of them to go in front of pumped mixer showers. They are not a substitute for a TMV and for bathtubs you should have a TMV as well.
Reply to the thread, titled "Thermostatic Mixer Shower from Woodburner Fed Cylinder" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
WHPES,
WHPES,
