J
jimmy73
i recently fitted a crosswater shower valve, the hot is fed via a suuey flange and a 1.5bar single impeller pump situated inthe airing cupboard. The cold is fed from its dedicated small tank through a 1 bar single impeller tank situated in the loft. this was the existing arrangement before i fitted the new bathroom. The shower wont maintain pressue with the hot pump kicking in and out and the shower going hot and cold. After advice from crosswater i've removed the check valves in the valve, these were supposidly conflicting with the ones in the valve, I've also change the cartridge. But the problem still exists. Not sure if its a valve problem of a supply problem. Scratching my head. 😡
