Hi guys. the company i work for has just taken on a job where a biulding required a big pool (not a swimming pool its about 5baths worth) it is sunk into the concrete floor by about 5 foot, the site manager is on about a system to drain it. it will require a pump to get rid of the water when the "pool" is drained. so obviouse thoughts are to get a proper waste pump at Approx £900ish but no thats to expensive,
the site has come up with an "idea" to fit a grundfoss Central heatin pump to a switch so that when the pool needs draining they simply turn the pump on and turn it off manually when the pool is drained.
to me this is very much the not done thing but its all about price with these guys, cheap is good for them.
i dont like the idea of fitting this as its not build to drain water its built to circulate heating water.
cant walk away from this job as the work is already underway, this was just a nice little change of plans they sprung on us.
what do you guys reckon? will it work? should i give in and fit it or not?
cheers all
J
cheers all
J
