F
Foston
I recently purchased a new towel rail but could not fit the two valves [Thermostatic and on/off] as the threads on the valve and radiator did not match up. The valves were purchased separately from the radiator but I did not see this as an issue. The on-line supplying company is sending a replacemnt radiator and hopefully the problem will not arise this time around. However, in considering whether or not to purchase a tap and die set I realised that I did not know the size or thread type in a standard radiator. Can anyone help please. Is it 15mm or 1/2 inch and is the thread BSP?
Many thanks
Many thanks
