Thread size on radiator inlet and valve
View the thread, titled "Thread size on radiator inlet and valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
F
Foston
I recently purchased a new towel rail but could not fit the two valves [Thermostatic and on/off] as the threads on the valve and radiator did not match up. The valves were purchased separately from the radiator but I did not see this as an issue. The on-line supplying company is sending a replacemnt radiator and hopefully the problem will not arise this time around. However, in considering whether or not to purchase a tap and die set I realised that I did not know the size or thread type in a standard radiator. Can anyone help please. Is it 15mm or 1/2 inch and is the thread BSP?
Many thanks
Forget the tap & die set!! Now just wait for the new towel rail. As the above post states should be 1/2" on the new towel rail but it appears you have a 3/4" tail for the valves on the existing pipework...
ive got a half inch and three quarter tap in my box of drills but cant remember the last time i used them threads are normally good nowdays but often needed then on cast boilers
Reply to the thread, titled "Thread size on radiator inlet and valve" which is posted in UK Plumbers Forums on Plumbers Forums.
Foston,
stevetheplumber,
