soneva
Hello,
First post 🙂 Hopefully in the right place!
I hope you guys can help to what could be a simple problem, but then again, it could be a big expensive problem!! Looked everywhere for the answer but still remains the same.
We have a 3 year old Tifell Eurofell M40 oil boiler which heats water on demand. Currently the central heating side is turned off by closing the inlet and outlet pipes at the back of the boiler and also the switch on the front panel is set to just produce hot tap water not hot tap water and central heating. I guess this rules out any thermostat settings problems on the radiators and the remote central heating controller.
As it is cold weather now the boiler does not produce hot water as it used to do, it only produces luke warm water with the tempreture dial on the front panel turned up to max. The tempreture gauge on the front panel displays 67 degrees when not burning whereas in the summer it was normally displaying 78 degrees. The boiler pressure has been at a constant 1.2 bar for well over 6 months. There are no errors displayed and the boiler comes on and goes off as expected without any unusual noises or signs of burning incorrectly.
Can anyone suggest what I can check/do to make the boiler produce hotter water? Is it some sort of internal theremostat maybe? Any help would be massively appreciated not only by me but by my two daughters, they think I have lowered the water tempreture on purpose!
Thank you for any assistance,
