tile cutter
View the thread, titled "tile cutter" which is posted in UK Plumbers Forums on UK Plumbers Forums.
hammers4spanner
Subscribed
Anyone know if the tile cutting machines from wicked or b and q are any good for porcelain tiles??
Looking for a cheapish cutter
I got a second hand rubi from ebay ts60 so it will cut a 600mm paid around £100for It and its head and shoulders above my old plastplugs thing
On a wet cutter it's mostly down to the cutting wheel. Get cheap, but great quality from here. Porcelain Continuous Rim Diamond Blade | ATS Diamond Tools
the cheap cutters do suffer from poor bearings. Thus makes the disc wobble, therefore, it might chip the tile or wander off line. This a good quality one.
Norton Clipper 180mm Table Wet/Dry Tile Cutter/Saw & Case flvtt180bm | eBay. Sell it afterwards for £80.
if you want a good porcelain manual tile cutter . Sigma are the best. They hold their money second hand too.Sigma 2D4 61cm Tile Cutter | eBay not cheap but has the breaking force to cope with and hard tile.
I've found that using the wet cutter even with a new wheel running true when I get to the end of a cut, and it's not with every cut, perhaps one in six or so the tile just doesn't cut clean and the corner comes away, just a little, but annoying al the same.
If you cut in 10mm from the opposite side first, then cut to if, this tends to stop it.
i have a beast of a wet tile saw and have to do that to prevent chip out.
I bought a cheap wet tile cutter, its taken some stick and still does a great job. Doing less tiling now so it will do for me. Think it was from toolstation.
Reply to the thread, titled "tile cutter" which is posted in UK Plumbers Forums on Plumbers Forums.
hammers4spanner,
AlexGas,
