Peter_Griffin
Good evening gentlemen,
From the start Im not a plumber 🙄 however I'm good at most things but this is getting the best of me.
Work has asked me to look at an electric water heater in a toilet that produces hot water for 2 sinks in there. Its a Santon unit (quite large) 3kW and is fed of the mains. It gravity feeds the sinks through a TMV which cold side is fed off mains to. Problem was that nothing was working so I assumed TMV was no good and replaced it. Water is now flowing but not exactly a good flow 🙁 and if you leave for say 5 mins then try the hot tap it feels very stiff as though there is build up of pressure and then water shoots out but then settles back to this slow flow.
I left it for like 15mins to take a call and again tried hot tap, water squirted and then nothing flowed at all!!! Then about 10 secs later slow flow again.
Could mains pressure be too much for certain TMV??
Other heaters in other areas on site are exactly the same but dont have this problem?
Please help as im lost 😕
