View the thread, titled "Toilet issues, cistern not filling up" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi all, just a side note to start, I am not a plumber and have pretty much zero knowledge about plumbing.
I have three toilets in my house, a downstairs one, big bathroom one and an en-suite one.
There was a rattling noise coming from the downstairs toilet whenever the chain had been flushed and the cistern had refilled. I bought a toilet fill valve from Screwfix, replaced the old one which was easy enough and the rattling noise has disappeared. While the main stopcock valve under the kitchen sink had been turned off, the en-suite toilet had been used and flushed, with no water refilling into the cistern because the water supply had been turned off. Fastforward a few hours later and the water will not return back into the cistern in the en-suite, even though the cistern is only about 1/10 full. I cannot get any water to feed into the toilet at all through the fill valve, even though this wasn't touched on this toilet. This en-suite toilet seems alot more awkward than the downstairs one - as I had thought about replacing the fill valve (probably completely unnecessary, but with having very little plumbing knowledge it seemed like an idea). I'm unsure if this is some sort of air lock in the pipes. This toilet has never had any issues and has always filled up fine, it all seems like a hell of a coincidence that I am now having issues with it having fixed the downstairs one. The big bathroom toilet is completely fine and having no issues.
Does anybody have any idea what could be causing this?
Many Thanks
I would take a look inside the cistern, make sure the float isn’t catching on anything. With the water being turned off, could have been some detritus in the system which has got stuck at the float valve.
Reply to the thread, titled "Toilet issues, cistern not filling up" which is posted in Boiler Advice Forum on Plumbers Forums.
