C
CCSwin
Hi
We have just moved into a 3yr old new build house i.e. someone else has lived here for 3yrs and we have just moved in.
We've been in for a few weeks and had no problem, however the toilet in the en-suite is now not flushing. The plunger device on the reverse side of the lid is a big circular disc and then that looks to push down a smaller disc. (I have a photo of the flush but am not sure how to upload on here?)
There doesn't look to be as much water in the bowl as there was before; so maybe i just need to add more water!?
Advice appreciated.
Many thanks
Fill cistern up to its line using a jug.
Replace the cistern lid, if everything flushes fine then you need to adjust/ replace the inlet valve.
If it doesn’t then you have an issue with the flush valve or button - there are so many of these that we can’t help unless you provide pictures.
