View the thread, titled "Toilet syphon replacement" which is posted in Boiler Advice Forum on UK Plumbers Forums.
FYI all, siphons are not measured in overall height but from the inside bottom of the cistern to the crown (spillover level).
No that it really matters nowadays due to the Dudley adjustable anyway! Useless info for y'all!!
adjustable one only one i use
Shaun so those pictures are of one adjustable syphon?
So whenever you replace a syphon this adjustable one is the one you always use?
I've searched and looked at so many different syphons/manufacturers recently, do you always buy that same one or are there others sizes they do (or is it one size fits all with the turbo 88)?
Yeah, saw that somewhere. That's one of the reasons I started this thread. Been interesting.
Ooops.
Just changed one of these today and fitted a Fluidmaster cistern kit to the cistern with flush lever.
The old one was knackered as the customer had adjusted and fettled with it over the years and finally managed to shear the part of the syphon that the linkage goes onto.
Fluidmaster dual flush kit with the cistern handle flush lever fitted no probs and all operates correctly and the flushes are more efficient than the previous setup.
Cheers,
Andy
Looked at these in plum centre. Look good, just the plastic handle puts me off where you have a metal one originally.
looks like you can replace the handle with a push button one too as long as the flush is not on the side of the cistern.
Yes it's the only one I use they last very well in a commercial environment
Shaun, got the Dudley adjustable, instructions mention on a close coupled cistern that the 50mm threaded tail should be trimmed to 2mm beyond the backnut when fitted to the cistern. Is this necessary? Will the cistern not fit to the pan if it is not trimmed?
All plumbers should guarantee their work, including the parts. Many warranties cover the plumber's work for up to one year. If the plumber refuses to guarantee his or her work, move on.
professional plumber Sussex County NJ
Including parts 😀 that's a joke parts have a manufacturer warrenty and not with the plumber,
Plumber warrents the Pipework / accessories etcs
New Jersey, USA ?
Reply to the thread, titled "Toilet syphon replacement" which is posted in Boiler Advice Forum on Plumbers Forums.
