hey guys
just got back from the property and seems like the tank has been filled, flush worked fine but again wasnt refilling
so it obviously is refilling but at a very slow pace.
just to make u aware i havent moved into the house as yet and when i leave the property i always turn the water mains off and back on again when i revisit. max time i have been at the house is 2hrs, so this is the max length it has been on. Do you think this is why the water is not flowing? because I havent left it on long enough?
here is another pic i have taken
we need a picture of the pipe that enters the cistern from below ( not inside )... coming from the floor
Try manually pushing down the black float. It looks real close to the cistern wall. It might be sticking slightly and not dropping.
If no water is still present then if it's mains fed you probably got a blocked orifice or stuck washer. Otherwise it might be an airlock if it's tank fed.
yeah it looks like the valve sticking , seen this a few times especialy with torbeck valves... they are stiff to the back or side wall of the cistern so have trouble rising and refilling, the fact that your cistern does fill eventualy means that the water isnt turned off...
