Toilets constantly running after regenerating air-gap on Megaflo
View the thread, titled "Toilets constantly running after regenerating air-gap on Megaflo" which is posted in Boiler Advice Forum on UK Plumbers Forums.
1st time poster here, hello all!
Recently moved into a property with a Megaflo system, started to have problems a few days ago.
Hot water wasn't coming through (boiler fired for a few seconds then cut out)
Constant dripping from overflow pipe
I don't know much about this system or plumbing in general so initially thought that these symptoms were somehow related, arranged for a boiler engineer (that I've used previously) to come round yesterday.
He identified that the air-gap in the system needed regenerating/replenishing - I had tried (and failed - shut off incorrectly identified cold mains) to do this the night before with no joy.
He sorted the air gap, confirmed that the overflow drip was due to a pipe that was leaking (not the tundish one), think it was connected to a Flexcon expansion vessel (this had also lost pressure so he sorted this too).
Although he said that this was unrelated to the boiler not staying fired for the hot water, this did seem to resolve the issue?, so all in all, boiler sorted, drip sorted, systems (megaflo and expansion vessel) both re pressurised.
However, today I've noticed that 3 out of the 4 toilets are constantly running (both upstairs and one downstairs).
Would love any pointers, have checked some previous posts online but these seem to be related to individual toilet faults, whereas it seems as though the issues I have now got could be as a result of the fixes that we implemented yesterday rather than individual components on the toilets.
Thanks in advance
Dave
Sounds like washers need replacing in bogs. When water turned off muck in or last straw for loos?
Thanks in advance
Dave
Hi there dave theres a good chance that dirt has gotten into the cold main , as its unusual for all the WCs to go at the exact same time , the cause may have been that the water board might have been working on your cold water mains (outside) and some dirt has gotten in, your plumber will manage to fix issue no probs or u might manage yourself if you can access the appropriate washers, (builders merchant)
what exactly is meant by regenerating air gap on megaflo plz almost 50 still learning
Mega flow (unvented cylinder) has an air bubble in the top of it to compensate for te expansion of the DHW when it's heated . Most cylinders have an external one. They operate on same principle as a ch expansion vessel apart from water is inside the rubber sack on a DHW one so it dosnt rust.
Basically the air is absorbed on a mega flow over time so u need to re generate. Involves draining off water.
I wonder if when the guy regenerated the air bubble he "fiddled" with the pressure reducing valve? Could be the reason for the dripping toilets.
Hi there I realised the expansion was within the megaflo unit had never heard of re generate before have googled it know and it all makes perfect sense thanks
I cannot see any way the megaflow work can directly effect the siphons in the wc's
So it can only be dirt stopping the bottom washer from seating down properly and allowing
the cistern to trickle into the pan. Easy just twist them off and have a look.
Unless something really silly and hot has happened to the cold supply deforming
the rubber seals ? no centralheatking
who said it was the siphons? Could all be internal overflows?
Turned off water and we all know what happens someone flushes bog FOV opens and scale moves or rubber deforms. Used to get it a lot on system swaps or re pipes.
Reply to the thread, titled "Toilets constantly running after regenerating air-gap on Megaflo" which is posted in Boiler Advice Forum on Plumbers Forums.
davefalcon,
Ermintrude,
