View the thread, titled "Tool for removing cartridge?" which is posted in Plumbing Tools on UK Plumbers Forums.
Hello all. I can’t stand my dripping tap any longer so trying to replace a cartridge. It’s a mono block mixer tap in the kitchen.
I can take the headgear off no problem but the cartridge is recessed inside the tap housing - can’t a spanner to it, and it doesn’t look like there’s enough clearance between the cartridge and inner wall of the tap housing to fit a socket wrench.
Is there a specific tool for this job that I don’t know about, or is it a case of in built obsolescence?
Thanks in advance.
Rob
I advised a fix on a tap for a colleague recently where he explained what I think is the same problem. I suggested that the shroud around the cartridge unscrewed to gain access. He insisted it was welded or one piece and the shrouds could not be removed. He showed me a picture and I was still sure the shrouds would unscrew. Armed with new confidence he had a go and they did screw off. Then he could remove the cartridge with an adjustable spanner.
Just saying in case this one is the same style.
You LEGEND! Thanks for that just unscrewed the housing on mine to reveal the cartridge.
Reply to the thread, titled "Tool for removing cartridge?" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
tool
Rob Eveleigh,
Mike Ballinger,
