View the thread, titled "Tool to siphon the last bit of water out of cistern" which is posted in Plumbing Tools on UK Plumbers Forums.
N
NGduffin
Hi, as the title says I'm looking for a tool, something like a hand pump, just to get the last bit of water out a cistern. I remember a plumber I worked with once had
a high pressure plunger like a big syringe so when submerged and the handle pulled it sucked water and held it. I wondered if any of the big diy stores sold them as I could do with one tomorrow.
Thanks all
Sponge is the easiest way. Flush the loo, and get ris of what you can, and use a sponge for the rest. Or the wet vac if you really can't spill a drop.
I tried the manometer tube method, and it takes ages.
flush toilet, disconnect all connections, lift toilet out and pour down toilet (if in rush and cant be bothered with wet vac)
dont take connection off as doesnt go in bucket, it leaks everywhere
dont use sponge or any other contraption as takes too long and never find it in van and it will break when rattling round the van!
I wouldn't be taking the cistern out to change the inlet valve, if it's the syphon then pouring it out is the way to go.
oh yeah, well if your good you cant get float valve out and new one in without removing all the water! as long as they havent siliconed it!
if its side float valve then u dont need to empty it!!
Very simple and very cheap, I carry a large turkey baster in my tool kit, it works a treat even fits into pipes
Got a battery siphon thing, the corgi magazine does them. Works o.k , you still need a sponge to get the last dregs. Its good for draining the u bend before you take a pan out.
Reply to the thread, titled "Tool to siphon the last bit of water out of cistern" which is posted in Plumbing Tools on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
NGduffin,
erpkid,
