C
capitanpugwash
So I'm down staying with my 84 yr old granddad and woke to a cold house as the boiler had stopped working. The condensate drain had frozen on his new boiler and he has been having to defrost it every few days at the moment. The boiler is inside his integral garage on the outside wall at high level. The condensate drains internally along the wall of the unheated garage in 20mm white plastic pipe. It has a steep fall along the wall (approx 4-5m long with a drop of 2m) before passign outside in 20mm plastic for approximately 6 inches draining into an outside trap. This appears to be where the condensate is freezing and blocking the pipe despite being lagged.
My initial thought was to enlarge the pipe to a 32mm/40mm pipe externally and for a metre internally with a trap to drain the 20mm condensate pipe into. The pipe however runs through a double skin external wall through a stone cladding. I am a few hours from home and have no access to a core drill to enlarge the hole which could be a real hassle with few tools. Having had a scan through here I have found that trace heaters may actually do a better job given that the weather outside is so cold even a 40mm pipe might freeze.
So my question is, would I need to run the trace heater wire along the whole length of the condensate pipe internally (4m) given that the garage is unheated and through the wall to the 300mm of pipe outside? Or just along the last metre or so internally including the outside pipe?
Can anyone who has used the trace heater recommend anything? I cannot get access to the installation instructions for the system like this even from the manufacturer's website.
https://www.abgo.co.uk/index.php?page=shop.browse&category_id=4141&option=com_virtuemart&Itemid=26
Any advice? or link to the full installation instructions?
Cheers
CP
Cheers
CP
