View the thread, titled "Trainee gas questions in this thread ONLY please" which is posted in Gas Engineers Forum on UK Plumbers Forums.
ive worked it out as you say and I get this, which tbf isn't goin to make much difference and is also going the rite way aslong is doesn't exceed the maximum permisable volume per hour.
8m of 35mm @ 0.00084 pm
7m of 22mm @ 0.00032 pm
12m of 15mm @ 0.00014 pm
8 x 0.00084 = 0.00672 m3
7 x 0.00032 = 0.00224 m3
12 x 0.00014 = 0.00168 m3
total pipe work = 0.1072 m3
meter (u6) 0.008 m3
total of meter and pipework = 0.01864 m3
+ 10% =0.001864 m3
total instantiation = 0.020504 m3
Right
if a zero governor actually pulls the gas through could that not lead to problems with other appliances if it overpulled or even lock up the meter regulator?
yeah I do have a viper im resitting so it is a few years out of date probably, the tightness test is a bit different to when I went through this last time il have a look in there see what it says
yes and no
if pipwork is sized correctly no as it will have the required amount of gas so wont pull from other appliances
yes if the pipework is too small / distance is too great for 15mm/22mm etc
have a look at H6
Yeah it doesnt include the meter in my book ...think that means its out of date on this?
no your right the formulas wrong in your first post should read
installation volume in cu meters = Vm + (Vp + Vf) = inst v
sorry about that will work it out again
same as mine but you have the fancy colour version
one less thing to worry about cheers
total pipe work volume = 0.01064 m3
+ 10% = 0.001064 m3
Pipework volume + 10% = 0.011704
meter (U6) 0.008 m3
total of meter and pipework volume = 0.019704 m3
total installation volume = 0.019704m3
nice one that looks like what I got now....sorry to be a pain but do you have any advice on unsafe situations? I find it a nightmare distinguishing between AR ID and NCS? is there like a rule of thumb? as an example one mock question was ...You see a scorch mark on a carpet below a radiant gas fire how would you classify the situation? I put ID as at any time it could set the carpet alight but the tutor said its AR which surprised me.
the carpet is only at risk of going on fire,
your thinking of spilling thats id easy way anything to do with fluing or on old boilers case seals id
Reply to the thread, titled "Trainee gas questions in this thread ONLY please" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
bassmonster
Joined
Location
Goodmayes, Essex
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
bassmonster,
acecharly,
