J
jimmycorkhill
Hello all!
I'm after some advice/help please re: piping/tubing connections. I'll try and explain my situation as best as I can. Please let me know if anything I say is unclear. (please see attached sketch).
I have a probe which sits in a water flow loop. The water flow pipe is what I am trying to specify and make (With your expert help!) The probe is attached to 1/4'' OD steel tubing and goes off to another system (which is irrelevant). The flow through pipe must have an ID which is able to incorporate the probe with a little extra space for water to pass around the sides.
I was thinking this might need something like a reducing tee piece which can create a water tight seal on one branch which connects to the 1/4'' OD steel tubing and the other branch and trunk can be the same size as long as the other branch has ID big enough to accommodate the size of the probe disc.
Any ideas/advice of parts and different pie sizes would be much appreciated! (and where I can buy from).
cheeers
cheeers
