For a log burner, I know it is possible to use twin wall flue to carry on from a brick chimney that has been shortened to below the roof. A plate/adapter to fix to the masonry and go from flexi liner to twin wall then through the roof.
Flue liner adapter plate (6 inch) - Twin wall flue - Twin wall flue systems (Black) 6 inch (150mm) t
My question is, can it be done on a chimney that has been lowered but is still above roof level?
the only info I can find is for where the brick chimney is truncated below the roofline.
If it can be done what would be used to cover the plate, flaunched??
