Two isolation valve on the same water pipe
View the thread, titled "Two isolation valve on the same water pipe" which is posted in Bathroom Advice on UK Plumbers Forums.
Hello everybody! I just need professional advice from you guys as i have never seen something like that before. In bathroom under the sink there is two isolation valves, they are about 400 mm above the floor level.Client wants to install vanity unit with basin which will make isolation valves inaccessible.
My question: Is it good practice(allowed) to install isolation valves inside vanity cabinets for easy access, and leave those two that will be inaccessible on the same supply? or its have to be only 1 isolator on the same supply?
Thank you for your advices.
A photo would have been helpful. Good practice and being allowed are 2 different things. Isolation valves are good practice, but not required. Any isolation valve that is required, must be accessible, such as a stopcock, an isolation valve for a cold water storage cistern.
A bit on the low side, but small bore isolation valves, so any additional ones could reduce performance of the taps. Is it not possible to remove them, extend the pipework and then refit them?
Its a bit low to solder them, specially the valve on the left,at least i can use compression coupler to extend the pipes. thats why i am asking if i add another two isolation valves inside vanity.
That’s fine to solder. I wouldn’t be putting compression joints in a place you can’t access.
What happens in 6 months when one of the joints has a leak. Gonna tip out the new unit to get to it?
Remove existing valves, pull olives/nuts, solder coupling and new pipe. For ease, can even use a solder ring coupling.
Edit: For peace of mind, wet the floor/area before soldering.
Thank you very much for your help guys.
I've found this sort of thing useful in that situation (if there's room to get it in!)
Reply to the thread, titled "Two isolation valve on the same water pipe" which is posted in Bathroom Advice on Plumbers Forums.
Mixmaker,
Ben-gee,
