Apr 27, 2024
North
DIY or Homeowner
The first showerpump i fitted close to the immersion with warix flange and it works fine for the small bathroom.
I fitted another pump for another shower in another bathroom about 2-3 metres away and that seems fine.
i am wondering if i am likely to encounter problems later with the second shower pump. I think the warix flange prevents bubbles and pitting.
thanks in advance
You're worried about the second shower pump that's a few meters away from the hot water source. The Warix flange helps stop air bubbles and damage, but you might have issues if the water pressure drops or if the pipes are too long. Air can also get stuck in the pipes, which could affect the pump. Make sure the pump is the right size for the distance and water use, and check that the pipes are the right size and properly insulated. Regular checks for airlocks and blockages can help prevent problems. If the pressure or performance drops, it might be worth checking the system.
