Aug 6, 2011
18
East Sussex
Heating Engineer (Has GSR)
Business Name
AqueousPlumbing
Can anyone tell me what I should be ordering from BES to get my 35[SUB]mm[/SUB] copper connected up to the newly installed U16 meter? I have just had installed by Southern Gas Networks a U16 meter with apparently, so the guy from SGN said a 1" meter connection size. My problem is that I tried to fit a meter adaptor rising BS 746 1" female X BS 746 1 [SUP]1/4[/SUP]" male (page 31 BES Cat P/N 0232 GAS METER UNIONS, ADAPTORS & FITTINGS) to Comp 35[SUB]mm[/SUB] X 1 [SUP]1/4[/SUP]"Parallel female (page 153 BES Cat P/N 9020 PIPE FITTINGS - UK COMPRESSION) and the threads don't allow engagement. So in short, how do you connect BS 746 to BSP thread tapper or parallel?
You don't, you use the correct fitting! If your gsr you should know this.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
