Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365Drill
View the thread, titled "Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365Drill" which is posted in UK Plumbers Forums on UK Plumbers Forums.
365drills
http://*********.com/boxset/ultimate_logo660.jpg
The most popular box set we have ever produced. A big hit with installers
http://*********.com/boxset/ULT1.jpg
[TABLE="width: 660"]
[TR]
[TD]
. 30 Diamond cores in a large heavy duty case complete with all tools.
Keep all your diamond cores together. Easy to spot colour.
Its not hard to work out why this set is a firm favourite with installers. Containing a huge number of diamond cores plus all the equipment required to use them efficiently. If you are looking for something substantial and you dont want to break the bank then buy direct from the factory at £199 instead of £299 retail.
[/TD]
[/TR]
[/TABLE]
[TR]
[TD="width: 190, bgcolor: #FFFF00"]What is it ?[/TD]
[TD="width: 454, bgcolor: #FFFF00"]What is it used for ?[/TD]
[/TR]
[TR]
[TD="width: 190"]5 x 6mm [/TD]
[TD="width: 454"]
For Red Rawl plugs and small fixings...... http://*********.com/jpgs/redplug.jpg
[/TD]
[/TR]
[TR]
[TD="width: 190"]6 x 8mm[/TD]
[TD="width: 454"]
For Brown Rawl plugs for heavy duty fixings..... http://*********.com/jpgs/redplug2.jpg
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x10mm[/TD]
[TD="width: 454"]
M6 bolts with rawl plugs and microbore gas pipe.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 12mm[/TD]
[TD="width: 454"]
Small LED lights .
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 14mm[/TD]
[TD="width: 454"]
M8 bolts with larger rawl plugs..
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 16mm[/TD]
[TD="width: 454"]
Snug fit for 15mm pipes.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 18mm[/TD]
[TD="width: 454"]
Oversized fit for 15mm pipes (Generous fit)
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 20mm[/TD]
[TD="width: 454"]
Electrical cables.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 22mm[/TD]
[TD="width: 454"]
Copper pipes exact fit
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 25mm[/TD]
[TD="width: 454"]
Tap holes small and 22mm copper pipes loose fit.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 28mm[/TD]
[TD="width: 454"]
Body Jets and smaller bore tap holes.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 30mm[/TD]
[TD="width: 454"]
Shower heads / shower rose.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 32mm[/TD]
[TD="width: 454"]
LED spotlights and lighting
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 35mm[/TD]
[TD="width: 454"]
Monoblock mixer taps
[/TD]
[/TR]
[TR]
[TD="width: 190, bgcolor: #FFFFFF"]1 x 38mm[/TD]
[TD="width: 454, bgcolor: #FFFFFF"]
Oversized for 32mm waste pipe
[/TD]
[/TR]
[TR]
[TD="width: 190"]
1 x 40mm
[/TD]
[TD="width: 454"]
Oversided for
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 45mm[/TD]
[TD="width: 454"]
40mm (ID) waste pipe for a bath or shower - Push Button flush
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 55mm[/TD]
[TD="width: 454"]
Push Button Toilet flush.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 60mm[/TD]
[TD="width: 454"]
Smaller shower valves. Access holes.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 65mm[/TD]
[TD="width: 454"]
Shower valves, Push button flush (large) Waste trap for showers
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x 115mm[/TD]
[TD="width: 454"]
Soil stack. Extract fans.
[/TD]
[/TR]
[TR]
[TD="width: 190"]12 x guide plates[/TD]
[TD="width: 454"]
Anti-slip plates to lock diamond cores to the tile surface.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x guide clamp for 115mm[/TD]
[TD="width: 454"]
Stainless Steel anti-slip clamp to guide the 115mm size drill.
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x J-hook[/TD]
[TD="width: 454"]
To remove (eject) the tile from inside the cores perfect on small sizes
[/TD]
[/TR]
[TR]
[TD="width: 190"]2 x sponges[/TD]
[TD="width: 454"]
To cool the diamond cores consistently and collect dust
[/TD]
[/TR]
[TR]
[TD="width: 190"]1 x heavy duty case[/TD]
[TD="width: 454"]Bright yellow and easy to spot. Extremely durable tough shell case[/TD]
[/TR]
[TR="bgcolor: #FFFF00"]
[TD="width: 190"]Wow ! [/TD]
[TD="width: 454"]The most comprehensive set we have ever sold ![/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ultimate_and_clamp.jpg
INCLUDES FREE CLAMP FOR THE 115MM DRILL !!
http://*********.com/boxset/ULT3.jpg
Re: Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365D
[TR="bgcolor: #000000"]
[TD="width: 190"]What is it ?[/TD]
[TD="width: 454"]How much would it cost [/TD]
[/TR]
[TR]
[TD="width: 454"]
5 x £7 £35
[/TD]
[/TR]
[TR]
[TD="width: 454"]
6 x £7 £42
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£15
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£15
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£15
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£15
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£18
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£18
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£18
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£25
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£25
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£25
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£25
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£25
[/TD]
[/TR]
[TR]
£25
[/TD]
[/TR]
[TR]
[TD="width: 190"]
1 x 40mm
[/TD]
[TD="width: 454"]
£30
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£35
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£35
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£35
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£35
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£60
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£24
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£40
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£2
[/TD]
[/TR]
[TR]
[TD="width: 454"]
£4
[/TD]
[/TR]
[TR]
[/TR]
[TD="width: 190"]
£600
[/TD]
[TD="width: 454"]
Total seperate value of component parts £600
[/TD]
[/TR]
[/TABLE]
LIMITED EDITION PRICE:
[SIZE=+3]£599 ? £499 ? £475 ? £399 ? £375 ? £350? [/SIZE]
[SIZE=+4]£299 !! [SIZE=+3]including VAT[/SIZE][/SIZE]
http://*********.com/boxset/crazy.jpg[SIZE=+3]FACTORY DIRECT PRICE - £199[/SIZE]
[SIZE=+2]THAT WORKS OUR AT A MIND BLOWING £6.69 PER DRILL BIT[/SIZE]
And you get the rugged box, the anti-slip guide plate, the anti-slip large size steel clamp, the cleaning hook !
At that price its a no brainer!! Yes I want one....
http://*********.com/boxset/ULT4.jpg
[TR]
[TD] This 3KG box really is the ultimate solution with 30 diamond cores in the most popular sizes and also now with and ever wider choice of sizes. Give yourself the best set on the market and grab it while you can at this price. Once we hit retail with it the price will go back to £299 which is still £250+VAT.
Retailers are already asking us when we can supply so we wont hold onto this price forever. Included with the kit is our latest innovation the stainless steel push clamp for the 115mm.
[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ultimate_side.jpg
THIS LARGE BOX WEIGHS 3KG (ABOUT THE SAME AS THREE BAGS OF SUGAR)
http://*********.com/boxset/ULT8.jpg
[TR]
[TD] Every single diamond core drill plus some more is included in this set. As a company we are very used to providing small kits and packs ideal for installers who just wanted to tackle a few pipe sizes. But this kit gives you the freedom to access any size drill core and not have to wait. Whatever the job throws at you then you can be sure you have the perfect diamond core inside the case. Never have to wait about on jobs for stuff to arrive.
[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ULT12.jpg
http://*********.com/boxset/ultimate_side2.jpg
[TR]
[TD] We put a huge amount of stock into the case so that you never have to be worried or caught out. The bright yellow case is in the colours of construction so that you cant lose it. And it looks cool as well. Did you know we make everything IN ENGLAND. And we have selected the best foam for this set. Not many people get excited about foam! But we do... And we know that every part of this set is superior. Obviously you can tell just by looking at the picture but you can be sure UK craftsmen have spent time and love creating this selection box.
[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ULT13.jpg
[TR]
[TD] Having a box is so handy because everything has its place. If a bit is missing then its obvious. Also its easy to grab and carry. And when its time to start drilling you want your equipment to be organised and to hand. The diamond cores are of exeptional quality and standards. Each has been tested by an independant UK company and approve stamped. We used a third party testing company so that retailers as well as installers can be sure of the results.
[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/clamp.jpg
http://*********.com/boxset/clamp_close.jpg
The steel clamp (non rust!) is perfect for the 115mm but we also punched out a couple of extras for you. There is a 6mm and an 8mm plus some other sizes so you can guide the diamond cores down with accurancy and create a sure start to the tile. INCLUDED FREE IN THIS SET !!!
http://*********.com/boxset/ULT11.jpg
[TR]
[TD] Laid out and ready for work. This system is going to look after you for many many top end porcelain tile jobs. Just seeing the equipment you bring to the job gives your clients peace of mind that you have the right tools. That you are a credit to your profession, that you are a professional who invests in his time, his skills and his tools. Quality equipment made in England.
[/TD]
[/TR]
[/TABLE]
[SIZE=+2] http://*********.com/boxset/365TOOLS.jpg[/SIZE]
http://*********.com/boxset/clamp2.jpg
1) Anti-Slip Guide Plates : 2) Water Cooling Sponge : 3) Cleaning hook [ YOU DO NOT GET THE BATTERY DRILL! ]
http://*********.com/jpgs/guideplate.jpg
[TR]
[TD]To start the hole push the anti-slip guide plate on the wall. Dip the tip of the drill into some water and that will be enough for you to get the hole started. Give it about 10 seconds of drilling until a pit forms. Now remove the anti-slip guide plate and put the soaking wet sponge under the core bit.[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ESS2.jpg
[TR]
[TD]To cool any of the drills use the handy sponge provided. Simply submerge the sponge in water (do not wring out) then push it against the rotating core bit. If you are on a wall and vertical then put the sponge underneath to catch all the debris. Easy way to do the job. If you are on the flat then simply drop a puddle of water onto the tile by squeezing the sponge.[/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/ESS4.jpg
[TR]
[TD]Finally - Insert the J-Hook (Its like a big toothpick) into the barrel of the 6mm or 8mm to eject any stubborn tile dirt or grit caught in the barrel - Easy![/TD]
[/TR]
[/TABLE]
http://*********.com/boxset/clamp3.jpg
http://*********.com/boxset/365Boxsets.jpg
[video=youtube_share;336x_HqvA78]http://youtu.be/336x_HqvA78[/video]
Lovely piece of kit, but the lack of a sponge with this kit is a deal-breaker!
says there is 2 sponges included better get your debit card out 🙂
Its in the kit !
Use this discount code to get £15 free delivery
(Case weighs 4KG!) next day delivery
Please note you do not get the dumbells! (its just a graphic to give you a clue how much the set weighs)
If I did want the dumbells.... how much would it be then
If I sold you their only set of dumbells they would get very grumpy.
And you wouldnt want that. Best stick to the yellow cases for a workout.
Has anyone used this kit? Is it any good?
They are popular - We are selling a lot of them (Well they are a great launch price) For example if you are VAT registered its only £165 quid [Note prices WILL be going up soon]
Maybe I will get Steph in the warehouse to put a message card in the box asking for product review. Its a new product so as soon as anyone does a review we will post it here.
Promising Start: So far we have had not a single complaint or return.
http://i415.photobucket.com/albums/pp233/hazellr/*********/How%20to%20drill%20a%20hole%20in%20a%20bath/steph.jpg?t=1405004093
Above is Steph and she is responsible for building the kits.
http://i415.photobucket.com/albums/pp233/hazellr/*********/Made%20In%20England%20365Drills/365drills5.jpg
Will ask her to add some cards in the boxes asking for client feeback
[video=youtube_share;JMrsqkCVZSA]http://youtu.be/JMrsqkCVZSA?list=UUoJNaIPLZgSte1xN-JvyF9g[/video]
Just to advise I will be working on a video to showcase the 115mm drill bit and how it helps with the install of the Soil stack (at 4 inches)
I have my soil stack pipe. I have my collar. And I have a tile. All I need to do is set aside some time to do the filming. Hope to get it done early September 2014.
Selling well but still waiting for customer reviews
Where do I get them from?
Have you got anyone over my way?
Are you looking for a distributor?
At the moment in 2014 the boxsets are ONLY AVAILABLE online direct from the factory.
We are looking at retail and have spoken to the buyer at Williams Plumbers Merchants as well as Tile Depot with a view to listing these. We are also talking to some other retailers with a view to stocking these in 2015.
http://i415.photobucket.com/albums/pp233/hazellr/*********/BOXSETS/bosets.jpg
We are working on the best way to display these via a point of sales - see example above.
So for the moment the only way to get your hands on a boxset is factory direct.
[DLMURL="http://www.*********.com"]How to drill holes in hard tiles with diamond core holesaw drilling bits[/DLMURL]
I'm on the other side of the world!!!!
Do you have merchants / suppliers in Australia?
PS - I was awfully helpful when you had your cistern problem.
Thank God - because you're a UKPF Sponsor.
Haha listen dont worry because we are exporting loads of these.
First good news you dont pay out tax!
So for example the £200 set is 20% cheaper at £166
(Thats because in the UK we have to add tax to everything)
But for export we remove the tax is AUTOMATICALLY removed if you order from our website and enter country "Australia".
YOU DONT PAY THIS TAX SO YOUR GOODS ARE CHEAPER
Then the only issue is the cost of shipping which is about £40 to FedEx for the big case which weighs a hefty 4KG (Quite a lump!)
So that means its back at the £200 mark fully delivered to anywhere in Australia by Branded Courier in about a week. So overall not bad !!!
PS: Dont worry about these UK boys paying that tax!
If they are VAT registered they dont pay it either... So they end up paying £166 a set too !
Rest assured, we have the same system over here.
Ours is only 10% though.
Should have bought a set 6 months ago - our dollar was quite high then.
I think the GBP is going to get stonger... High employment and strong UK forcasts.. Dont be suprised to see 2AUD to 1GBP soon !!
Prices are not going down for anyone at the moment :nonod:
Just sayin !!
This still 199 all in delivered ??
Its £199 and basic delivery is 4.99 for the Ultimate (Biggest set)
http://www.*********.com/boxset/ultimate_and_clamp.jpg
I clicked on the above link, hoping Laura (girl in picture) will have her kit off and show me how to drill tiles with the said drill bits? Instead, she had all her clothes on and showed me nothing with the drill in action? Damn, I'm dissapointed
[video=youtube;wke9hh1uJM0]https://www.youtube.com/watch?v=wke9hh1uJM0[/video]
Have a giggle with this video then...
After seeing that Sera perform the drilling motion in the nude, I have placed my order. Just a bit worried though?
- They never asked me for the 3 didgit security number on back of my card?
- They made me fill a form about: 1) How did I hear about them? 2)Any comments? I made them aware that Mr 365 Drills refused to give us UKPF members any discounts? He made us pay same as any other member of the public???? I'm not impressed 🙂
although i dont have this kit i have used the much smaller bathroom installers kit and i can confidently reccomend 365 drills products.
errrmmm, let him fight his corner kay-jay. Don't do it for him 🙂 In all honesty, I'm sure Dan wouldn't have had him here as a sponsor if his products were not of high standards.
I'll check my box when it arrives. Hope there'll be some sweets and biscuits in there.
Reply to the thread, titled "Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365Drill" which is posted in UK Plumbers Forums on Plumbers Forums.
365drills,
village idiot,
