View the thread, titled "Ultracom hxi - Hot Water Only" which is posted in Bathroom Advice on UK Plumbers Forums.
M
malcyt
Hi can anyone tell me if this boiler has a manual override mode so that it can be controlled(satisfied) by the HW cyl stat only without the internal timer being set? The one I am looking at has the options board installed but not the Baxi additional controller so all control is at the boiler end. HW only mode only seems to work when timer is active.
Can't see anything in the Install or User Manual that says it has this override mode.
cheers
Malc
hi not sure what you asking but the internal options board can de switched off and the demand operated as a switched live .not sure what option in the menu that it is
regards ant
Reply to the thread, titled "Ultracom hxi - Hot Water Only" which is posted in Bathroom Advice on Plumbers Forums.
