View the thread, titled "Un-sleeved gas pipe, landlord saftey check." which is posted in Gas Engineers Forum on UK Plumbers Forums.
depends how you interpret turning off the appliance/install
NCS - doesn’t exist anymore, do whatever you want
AR - isolate at Gas supply or remove fuse from
Spur with permission, attach label and issue notice
ID - disconnect, or my interpretation (cap off if going back tomorrow) and attach label/leave notice. I physically do not know where you are saying I am wrong?
It maybe me just being stupid?
just with with sleeve theyve upgraded it from ncs to ar which i dont agree with
so ar is cap the supply
Nope, because you remove the fuse from the spur or turn the gas tap to off position or pull the ecv to the off position (this is not a cap as you can Turn it back on with minimum effort). When you cap something you are disconnecting it from the supply. You only disconnect on an ID. NOT AN AR.
Edit due to bad grammar
how do you isolate the install?
Yeh I get where your coming from I think. If you can't isolate supply appliance without isolating whole install affecting other appliances then you would can it at appliance but that's quite a rare occurrence...
But that isn’t what the GIUSP say. That is an isolated instance that you would deal
With when in that position.
Reply to the thread, titled "Un-sleeved gas pipe, landlord saftey check." which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
Matt0029
Joined
Location
leeds
Heating Engineer (Has GSR)
Thread Information
Title
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
Matt0029,
Darren Jackson,
