Unable to adjust co2 readings vaillant boiler
View the thread, titled "Unable to adjust co2 readings vaillant boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Unable to adjust co2 readings on a a vaillant ecotec boiler it’s an lpg model I’m currently getting 0.0004 ratio, can’t get a higher co2 percentage than 8.6% (minimum being 9.7 without cover) and the ppm is around 40
Have tried new gas valve new Venturi and new pcb. I’ve cleaned burner and condensate pot and checked flue integrity which is coming back spot on the gas inlet supply is correct aswell
Have called technical help at vaillant but they are about as much use as a chocolate teapot
Yeah I’ve been trying to adjust it but it won’t go higher it will go lower but The MI say the allowances for co with no cover is 9.7-10.7 for lpg models this is the problem I’m facing
Reply to the thread, titled "Unable to adjust co2 readings vaillant boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Gasssssssss,
Deleted member 120897,
