This is a fairly common occurrence. Any deposits of powerflux or similar o an anaconda has the potential to nibble through within as little as a few weeks.
As stated, when TT be careful to avoid regulator lock up.
I will sometimes do a let by test, then slowly raise to an intermediate level,,say 15 mb and closely observe then raise to final test pressure of 20mb avoiding lockup.
Even so ,it is entirely possible to have a pin holed flex due to flux that will hold a correctly applied TT and will only leak intermittently.
Remember the flux is semi solid and can easily plug a pinhole and then if ambient conditions change (eg warm weather) ,the flux blob softens and it blips some gas out again.
Even squiriting with LDF needs care as it can sometimes wash away/soften flux blobs thus revealing a leak but it can also seal up the leak !
True ,,it all creates valuable work and generates income..keep blobbing lads .
Only slightly relevant but nothing downstream of the ECV belongs to Grid or the transporter. If anything downstream of the ECV eg meter/reg is duff then transporter/grid may replace/rectify as long as there is a contract in place. This is then internally billed to the equipment owner kerching $$ keep blobbing..
You All seem to be forgetting the Anaconda is at 75mb (medium pressure) as its before the regulator.
Also the meter govenor is always in lock out if no appliances are in use.
Thats the reason you LDF the anaconda its the higher pressure.
Not during a proper tightness test it's not. As long as regulator is functioning correctly.
This is why tightness test is 20-21mb. Regulator should not lock up until 3-5mb above WP.
This then tests everything downstream of ECV. So there no requirement to LDF anaconda unless you have a drop and are tracing a leak.
I only recently did my acs and they say i should ldf anaconda and if it lets by i could crack the nut and ldf inside!
I said why would i do that its not my responsability and they said well you dont have to but you could if you wanted to. I think thats wrong so inwont touch it anyway!
Ldf the anaconda was advised as a must
Maybe as it reached standing pressure it was enough to cause the leak?
you made it then? lol
I only recently did my acs and they say i if it lets by i could crack the nut and ldf inside!
think you would find thats a 'you could crack the nut and ldf inside, but the transporter wont like you doing so as it belongs to them' thsats because you cant do anything lawfully to it.
Advised!
Comes down to personal preference I think.
Wasn't a requirement to do it on my ACS 5 years ago and I never have unless I have a drop and suspect Anaconda is compromised.
Also resat my ACS 3 weeks ago now and had question asked by my assessor.... after a successful tightness test carried out to standards are you required to LDF the Anaconda?
My answer was NO as tightness test was sound! Correct!
I was always taught three sprays. One on the Ecv Union, one where the anaconda meets the regulator and one on the test nipple.
