Plastic should be fine, just make sure you use a back flow prevention device where the supply leaves the house
But we all know that's never going to happen in this circumstance so a double check will be better than nothingProper air gap necessary for that.
Because I didnt think the OP was a Plumber just checked seemed I was wrong, still be surprised if it is fed from a tank thoughWhy not?
Reply to the thread, titled "Under water service or isolation valve" which is posted in Bathroom Advice on Plumbers Forums.
