PlumbingBud
I had a bathroom job and whilst I was there the customer mentioned a drip on the waste pipe system going into the soil stack.
Turns out the soil stack was blocked up to about 7ft above ground, but rodding only partially shifted the blockage. Anyway, after much hosing and faffing, water started to trickle upwards from under the driveway, like the Peckham spring.
After some digging the we found the clay drain pipe and it turns out to be cracked on the flange and debris has fallen into the pipe. It had obviously been like that for a good while.
It looks like we may be able to fix it, but it is a big, smelly, dirty job and its going to be 2 days before I can get back due to other commitments.
Question is, how hard are clay pipes to fix with plastic soil and adaptors. Also, what kind of charge would you guys be thinking of.......?
Cheers.
Cheers.
