Underground lpg gas pipe
View the thread, titled "Underground lpg gas pipe" which is posted in Renewables on UK Plumbers Forums.
Thoggy
Hi
Got to put some lpg gas pipe underground and just weighing up mdpe gas pipe versus Tracpipe, just seen the cost of Tracpipe wow!!!
Only thing is it seems that the Tracpipe is going to be better to bend for when I connect abouts ground, I see the mdpe has electrofused joints which I wouldn't have a clue how to do so will leave that, has anyone used mdpe before for gas and how did you go on?
At the minute the safest bet looks to use the Tracpipe but it's extremely expensive.
Thanks for any advice
Have a look at gastite and if your doing elec fusion joints there's a separate qualification 😉
Bring it up in a hockey stick and then use a transition coupling.
Why are you needing to bend it tight?
How much are you going underground you can buy tracpipe in 5m or 10m kits, i had to run a LPG pipe underground through 4 inch ducting and i used tracpipe 5m installation kit came with fittings for both ends cost me £80 and done within 15 mintues
Copper potentially get crushed underground even if coated. Make sure to lay at correct depth for foot or road traffic as required.
Reply to the thread, titled "Underground lpg gas pipe" which is posted in Renewables on Plumbers Forums.
Thoggy,
Vee,
