Guest viewing is limited
Understanding head of the drain with regards to stub stacks HELP PLEASE.
View the thread, titled "Understanding head of the drain with regards to stub stacks HELP PLEASE." which is posted in UK Plumbers Forums on UK Plumbers Forums.
H
heatho87
Hi Im finding it hard to understand about the head of the drain and stub stacks if /were they can be fitted etc
Am I right in saying you can have a stub stack at the head of the drain!!!
Help please!
An unventilated stub stack terminated with an access fitting is a secondary stack may be used to connect a group of ground floor appliances to the ventilated building drain provided the vertical drop to the invert level of the drain does not exceed 1.5m from a WC and 2.5m from a waste appliance. If you have more than one stub stack the head of the arrangement has to be vented to atmosphere or AAVs added to each stub stack arrangement. I hope this helps you.
in short the head of the drain should be a ventilated stack, subsequent ones can be stub stacks
Reply to the thread, titled "Understanding head of the drain with regards to stub stacks HELP PLEASE." which is posted in UK Plumbers Forums on Plumbers Forums.
heatho87,
fuzzy,
