Hi, we are going down under for 3 months in January and have been taking advice on what to do to avoid frozen water pipes etc. Trouble is we have had two conflicting views!
I should also say that our house insurers have no specific requirements relating to water/heating in these circumstances.
We have a Logic 15 boiler and rads throughout the three storey house, a Kingspan Range Tribune HE indirect hot water cylinder sealed system and associated bits, all of which is controlled by Danfoss TP9000 and a TP5000 on the top floor.
One firm told me to leave the system on as normal, and set the thermostat on low say 10/12 degrees. Then another advised draining everything down, turning water and boiler off, then recommissioning when we return.
I'd welcome views, particularly from professionals, of which is the best and safest solution, also if we could leave the system on a low temperature setting, but turn the water off at the mains stopcock, to at least avoid flooding if a leak did occur or if for some reason the boiler decided not to ignite.
