Unvented cylinder advice
View the thread, titled "Unvented cylinder advice" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
michaelp
I have a 210 litre Santon unvented hot water cylinder. The house was built just less than 5 years ago. Yesterday it was dripping through the Tundish whilst the water in the tank was heating (indirect from a Vaillant boiler). It stopped dripping when the water stopped heating. It was dripping like this 13 months ago and cost me £180 to have the combination valve replaced. The original installer has been back to service the boiler annually, and also been to do any other work we've needed, although it's a nightmare getting hold of him. He's a really nice chap, but has more work than time. I have left a message (but doubt I'll hear anything anythime soon as it can take months to get them out). To the best of my knowledge, they have never checked the pre-charge pressure in either the Extravalem unvented expansion vessel or the Boss vessel on the closed heating circuit. Instructions say these should be checked annually.The Santon instruction book says that if it's intermittent, re-charge the expansion vessel to 3.5bar (it also says if it's dripping continuously, check pressure and replace the 'Pressure reducing valve cartridge' (rather than the entire expensive combination valve) or clean the strainer).The Extravalem expansion vessel is located awkwardly behind the hot water tank, about half-way up the said tank, and has the water entry at the top. Santon's schematic shows the vessel placed higher up and bottom entry.I would be very grateful for some opinions on this please, as I am rather wondering whether the right job was done last winter or whether it actually needed the pre-charge re-pressurised?I would also appreciate any comments on the vessel being installed top entry, although suspect it doesn't matter.(I had an expansion tank in a previous house, but that was only for a negative head 'shower' pump and I was instructed how to annually check and adjust the pre-charge by the manufacturer's engineer. I'm a Chartered Physicist so I do understand and appreciate the importance of proper operation of an unvented hot water tank, and feel I'm currently depending on a safety device to prevent failure)Thank you.
basically, get another g3 qualified engineer out to do the checks if your current guy hasnt turned up. loss of expn vssl pressure will cause dripping but main rule is that only original manufacturers parts should be used if changing them. unusual for a combination vavle to fail so quickly, normally problems are to do with the expn vessel.
the pressures are normally checked as part of an annual service/check, especially on the unvented side. It could be the issue but the problem with giving any advise on a forum is that if something else is wrong it can lead to a more dangerous situation. So the best advise is to get a qualified person in to look at it.
maybe somebody on this forum lived near you and could take a look.
Thank you for your comments, although it's easier said than done to find the right person. Chichester area....
Reply to the thread, titled "Unvented cylinder advice" which is posted in UK Plumbers Forums on Plumbers Forums.
michaelp,
codcutter,
