Nov 11, 2018
46
DIY or Homeowner
Hi, looking for advice about unvented cylinder. I had one installed as part of a horrific modular loft conversion that was recently finished. The water pressure in the bathrooms is poor, probably worse than when just had combi and I cant use two showers/bathrooms at one time which was the point in having it installed. When first installed it seemed good but then there was a leak in the system. Leak was fixed but pressure now poor. The tested cold incoming measures at 22 lpm and 3 bar but when i check this in bathrooms its less than 8lpm. The plumber is refusing to return as loft company arent paying him(think theyre going under) and his only advice is that the incoming supply is the issue. Im not convinced though due to rate during test and i've recently tested outside tap and its 3 times quicker than inside. The new shower in loft occassionally has fluntuating pressure that you can see by eye. Does anyone have any advice?
  • Informative
Reactions: Frelon
Any updates Tim I’m intrigued
So spoke with manfacturer and they advised its not certifiable and will have to come out. They advise that its a performance issue rather than a safety issue and ive email structural engineers to confirm point loading. Contacted loft firm who acted very surprised even though they've clearly made a timber frame for it to sit when should have bracket. Ive requested the certs of installer - gas safe and G3. I spoke to manufacturer about pump on return and they said thats normal for horizontal but not needed for vertical so a definite bodge. What makes this all the more worse is that this was installed the day after the painters finished! So house was ripped apart to install something that would never recieve sign off and isnt fit for purpose. This comes after 3 months of pain with builders that didnt have a clue about building regulations. Looks at landmark lofts website and see how polished the marketting is. Feel like such a mug for falling for it!
Happens so often mate and I’m sorry you’ve been stung. I’d be very very surprised if the “plumber” is qualified. I don’t think you’ve “fallen” for anything how do you know unless you’re a mind reader. I’m guessing by the way you’re talking that they weren’t the cheapest as we so often hear about. I’d be tempted to send the same request for credentials to the plumber
Also you mention that the cylinder has had a wood frame built it’s an irrelevance as the thing shouldn’t be on its side
Yeah i know that but considering loft firm do 3 modular lofts a week, and many will have cylinders, they must have known what they were positioning was incorrect - apart from anything else it didnt have bracket and they had to fashion one out of timber
If you suspect that this is not a one-off problem with a subcontractor that is going to be quickly and effectively sorted-out by the main company, you may find that Watchdog is interested in your story:
BBC One - Watchdog - Send your story to Watchdog
  • Agree
Reactions: Riley
Well yes I see your point however not all houses are going to have cylinders. I’d never put them in the eaves unless there was exceptionally good access going forward. How is the annual service going to be carried out otherwise
You think if they have done the same
In addition if I were you mate I would be tempted to get an independent assessment carried out as soon as possible before anything is attempted to be corrected
the problem is that I reckon the firm and the plumber are going to liberally blame each other this could all be down to a muppet of a “plumber” advising the loft co what they need. I cannot believe that if this guy is a qualified plumber that he would have attempted to fit this cylinder this way
Well I reckon quite a few of them have cylinders as the selling point is that its the only opportunity to have in eaves. Photo of how module came, so two bits together with all pipework to eaves already completed in factory. The loft firm spec'd it and run the flow/pressure test.
These are the modules
