Unvented discharge at high level current regs
View the thread, titled "Unvented discharge at high level current regs" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged in to a downpipe. Presumably metal. Anyone recently noticed this or done this thanks.
Thanks, sure it used to say as a last resort you could turn back to the wall they must of got rid of this? They must be implying metal down pipe if discharging at high level and going on to down pipe?
They did but it was only as a last resort and they didn’t like it so they just said no in the last update due to risk of scolding
The regs I have maybe abit miss leading then. As you say plastic pushfit is rated
Reply to the thread, titled "Unvented discharge at high level current regs" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Matt0029,
