Unvented hot water, poor flow. Blocked filter?
View the thread, titled "Unvented hot water, poor flow. Blocked filter?" which is posted in Bathroom Advice on UK Plumbers Forums.
R
RoyalCrabs
Hi guys!
Dealing with an unvented Hot Water cylinder that has apparently been fine till a few weeks ago. Someone decided to turn the mains stopcock right down as the pressure was 'too high' and over time the flow rate has reduced to a trickle when left on for 10-20 secs (hot water..).
I suspect the cylinder isnt filling quick enough to keep up with the tap outlets (same story with every tap in the house, worse upstairs for obvs. reasons), could it be a blocked filter on the inlet to the cylinder?
Not worked much on these systems before but have a rough idea.
Any thoughts would be appreciated, like I said I think the filter could be blocked but not sure.
Thanks!
Reply to the thread, titled "Unvented hot water, poor flow. Blocked filter?" which is posted in Bathroom Advice on Plumbers Forums.
RoyalCrabs,
chris watkins,
