Hoping someone can sanity check me!
Bit of a project house - had an unvented cylinder fitted in the loft around a year ago. Gledhill horizontal, Worcester system boiler as well as wet underfloor throughout.
As part of this we had a new 32mm MDPE mains fitted. This enters the house and reduces to 22mm. Also have a minimax M2 softener.
Cylinder is supplied via the 22mm after the softener. We have cold kitchen tap and one 15mm feed (Currently isolated) pre softener. Everything else is on the balanced cold and softened.
The issue I’m having;
Recently fitted a bath. At first the flow is excellent and as I would expect. However after about 3 minutes of filling there is some awful water hammer (I suspect from the cold supply to the cylinder) and flow is massively reduced.
I have a calibrated flow and pressure gauge - connected to the 15mm supply pre softener (so as close to incoming mains as I can get) I’m seeing just over 4bar and 35lpm.
Using another 15mm supply but this time a softened hot one - initially I see 3 bar and around 30lpm. However this reduces after a few minutes to 20lpm. After immediately isolating pressure sits at 2bar and slowly creeps back up to 3 after a minute or so.
Bypassing the softener makes no difference.
Before I call my G3 guy - would I be right in suspecting the combination valve may be faulty or slightly blocked etc? My thinking is the cylinder isn’t being replenished quickly enough so it’s relying on the pressure from the expansion vessel for that initial burst which is then unsustainable. Checked all accessible valves and all are fully open.
Or am I just expecting too much of the unvented and this is usual behaviour? We have only had shower run via 15mm so this hasn’t really been noticeable until now.
